HELP - getting new mobo started
PhaseZero
I replaced my old p4 system with my new vnf3-250 and amd 2800+. I can't seem to load windows without running into a stop error message. I've updated to the latest bios. I've already tried repairing windows twice but i still run into the same error. It's really important i keep the data on the drive. Heres the error message i get.
" A problem has been detected and windows has been shut down to prevent damage. If this is the 1st time you've seen this stop screen, restart, if it appears again follow these steps.
Check to be sure you have adequate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters.
Check with your hardware vendor for any bios updates. Disable bios memory options such as caching. If you need to use safe mode to remove or disable components ..press f8.
Tech info : Stop: 0x0000007E (0x0000005, 0xF86F6750, 0xF894D454, 0xF894D154)
This error is often caused by bad/unupdated video driver or directX version. Try to update them first.
If you still get the error after that, try to disable Video Shadowing and BIOS Shadowing, and set the RAM latencies to something near 3-3-3-6.
thing is, i can't get into windows to update any drivers. I tried changing ram timings but i'm sure that isn't it. I can't find those shadowing options either.
Just my opinion, but make sure your not overclocked or anything in case that is the problem.
I've never had luck using the WindowsXP "repair" option. Or at least it has never did anything for me. Most likely you would need to reinstall Windows, especially if you installed a totally different motherboard.
Unless someone else knows another way.
Can you get into safe mode by tapping F8 on boot up? If you can get into Safe Mode but not normal windows, then it's most likely a software problem like a driver, XP config or maybe even a virus.
However, if the comp craps out even going to SM, then chances are good you have a hardware issue like HDD, PSU or Mobo. I would definitely reset BIOS to defaults, unplug any unnecessary peripherals and PCI cards and then try Safe Mode again. Also, take your side off your case and get a room fan blowing on the components in case it's some kind of heat issue...
What sort of data is most important to keep?
My money is on it being an OS problem, due to swapping hardware. The repair option is shady. You should reinstall the operating system, without formatting your hard drive. Thus, should lose virtually nothing besides programs actually being installed. (they will still be present on your hard drive)
Your my documents folder, internet shortcuts, etc, won't appear to be present when you boot into windows for the first time but I believe they will still be recoverable on your drive.
