Help getting internet working on P5N-E SLI
Viperlover
OK, I just put in the new motherboard and am starting fresh on a new XP install. I just can't seem to get internet going on it. I installed all of the motherboard drivers and everything but no internet. What do you guys think it is?
Check the BIOS to make sure that it is ENABLED. Only thing that I can think of off the top of my head.
...and by "no internet," what exactly do you mean? ...since you're obviously on the internet to post your message, hehe. Is the NIC connected to a router or modem? are the LED lights on the RJ-45jack blinking? Do you get an IP address? Is the device enabled in device manager? Were the NIC drivers installed?
I have it hooked up to the same ethernet cord as I had before, and its hooked up to a router just as before. There are 2 lights on the end of the cable, red and orange, but they are not flashing. I have installed everything on the motherboard disk, but I never saw anything on it specifically for the internet, like a icp protocol or anything. I get an IP address either.
And you verified your LAN port/RJ45 is enabled in the BIOS? Have you then checked under the Device Manager and seen that the drivers are installed OK?
The port is enabled in the bios, and where is the device manager located? I can't seem to find it.
Which end of the cable has the lights? Both ends should have LEDs, lol, on the router, and on the motherboard. Are any of those LEDs lit? There should be an ethernet controller driver on the motherboard disk. What motherboard do you have? What is the IP address you're getting? Device Manager is under My Computer properties >> Hardware >> Device Manager, and all the Network adapters should be enabled.
Only one end has lights, and that is in the back of the computer, and they are constantly on, not blinking. I have an ASUS P5N-E SLI and I meant to say that I wasn't getting an ip address. Everything having to do with the 650i ethernet controller is enabled and all of the drivers appear to be installed.
The "network Adapters" show up properly in the device manager? Also check the Network Connections in the control panel.
EDIT: I see that you are running thru a router. Do you happen to have MAC address filtering on? I ran into that prob with mine.
yes the nvidia nforce networking controller shows up, which is the motherboard network adaptor. As well as the 1394 network adaptor.
Wow. I have no clue what I did, but it works now...
Thanks so much for the help guys. I really appreciate it.:)
