Lastnight as I was using my computer colorful characters started to appear on the screen, than a flash and the computer rebooted. It would reboot but after a few seconds those characters would appear and system reboot. Then it got to the point where it would not even run through post. I removed all connectors from drives and fans, blew out case (lots of dust), I noticed that mb power supply connector was not down fully. I corrected that. When I went to start computer system would come on an imediately shut down. Fans would start and stop almost imediately. I disconnected 3 of my hd. System booted fine. I reconnected each hd drive 1 at a time restarting the computer after each connection. Computer booted fine with all 3 connected. This morning I turned the computer on an it shutdown almost imediately again. It won't run unless I leave at least 2 harddrives disconnected. It doesn't matter which 2. I can boot with 3 of my drives. My system includes the following:
Gigabyte 7vrxp v1.0 MB
1 gb of crucial pc2700 ram
Sapphire Radeon 9500 Pro not overclocked
1 250 gb Wd hd
2 120gb maxtor hd
1 80gb maxtor hd
1 60gb maxtor hd
Athlon Xp +1700 not overclocked w/ thermaltake Volcano 7
Nec 1100a Dvd+rw
Liteon 52x24x52x Cd-rw
Ide floppy drive
Power Supply is the Turbolink 420W that was recommended as a good buy about 1 year ago in the hot deals thread.
Also I have a transistor that lights up near the power connector on the mb. I have never noticed it before today.
After originally posted this message I reconnected all the drives and system is working. Could this be a power supply problem? I am planning on removing 2 of the hd as soon as possible.
Any help would be greatly appreciated.
1 250 gb Wd hd
2 120gb maxtor hd
1 80gb maxtor hd
1 60gb maxtor hd
Nec 1100a Dvd+rw
Ide floppy drive
