I have an Antec Sonata Case which has front headphone and mic ports, and I have a SB Audigy 2.
I would like to hook up the front ports to the audigy if possible. The pin connectors coming from the front are labeled as follows, with what I assume they are used for:
AUD GND (Ground)
FPOUT - L (Output)
FPOUT - R (Output)
RET - L (Input)
RET - R (Input)
MIC (Microphone)
MIC-BIAS (????)
Is there any way I can hook this pins up to the Audigy so I can have Front Panel audio inputs?
AUD GND (Ground)
FPOUT - L (Output)
FPOUT - R (Output)
RET - L (Input)
RET - R (Input)
MIC (Microphone)
MIC-BIAS (????)
