A couple of days ago, I boot up my pc and I noticed the logon screen for XP looked a bit odd. The resolution is usually at 1280x1024 but the screen was showing 640x480 @ 8bit and the edges were pinched at top and bottom like so: ( )
After logging in, checked out my display settings and the monitor was no longer detected as Nec FP912-SB, but as a 'Plug and Play'
monitor!
I've tried reinstalling the newest version of Navi-Set, but it won't detect my monitor at all and continues to ask if I would like to redetect the monitor.... I've tried all the solutions on the nec support page for monitors that are not being detected, but to no avail.
I've reinstalled my forceware drivers and still nothing.
I also noticed that the screen is pinched during the boot-up (ie. during post etc..) So my assumption is that the monitor is not communicating with the pc from the very start and this may be an internal issue with the monitor itself rather than a driver issue.
Has anyone else experienced this problem?
thanks in advance!
monitor!
thanks in advance!
