I've already posted my trouble in other 3d because there I've seen perfectly working what I try to do.
First of all sorry for my bad english.....it's not my native language.
I have a big problem with my displays' setup and I'm arrived here at the end of a very long research!!
I'm a woman but I've always assembled my pcs. With the last one I decided to put 2 graphic adapter (X1950 pro) not for a crossfire setup, but only because for my job I need a big monitor and 2 other monitors for palette and so on....
I want to buy a 30" monitors and I already have 2 19" Multisync LCD.
The problem is that it's impossible to have both card working
I've installed a second X1950 Pro card. The first one is an Asus EAX X1950 pro, the second one the same card by ATI. I've uninstalled the old Catalyst (7.2) than I have rebooted and in Device manager I've found the 2 X1950 pro. Then I've reinstalled the Catalyst (7.10) e newly I rebooted. I DON'T WANT A CROSSFIRE configuration, I only need to have on the first card a 30" monitor and on the second card the two 19" monitors.
In Catalyst control panel I see now 4 icons (1-3-2-4 displays)but I see only one card listed with a monitor. If I enable the monitor (3) in the second card, I can see for a while the desktop in the second monitor, but in a couple of minute all disappear, I see line e points and then Vista (ultimate X64) crashes. (I link some screen to better explain)
When I've rebooted I've seen this warning
and this description:
If I don't attach any monitor (display) on the second card, Vista64 works fine, only if I enable the monitor on the second card Vista crashes.
I've tried with and without the two crossfire bridge molex: same effect.
I don't need crossfire but only to have 1 30" display on the first card and on the second card Other display.
I think that the problem is in the Catalyst driver because it's in that control center that I don't see the TWO card listed, while Vista device manager has both.
I see here more than one people with 3 o 4 display configuration and the one I quoted with a similar card and pc too. I wrote to ATI but it's absolutely useless: the last answer is this one:
Another is:
After many test I got in Catalyst Control panel the 2 X1950 Pro, but every time I enable a monitor on the second card in a few minute Vista crashes.
So can i have to do?
I know that my english it's bad.... sorry about that, but here where I live I don't know any one and the only store here is a Future shop....... I moved here some month ago and I'm without any computer geek friends ....
I have assembled my pc by myself with no problem but with this situation .....
What can I try?
Please Help me, poor woman in big trouble!!!
Thanks so much for any help.
My configuration:
CPU| Conroe E6600 Mobo| ASUS P5W DH Deluxe RAM| Mushkin XP PC2-6400 4GB 2X2GB DDR2-800 CL4-3-3-10 VGA|2 x ASUS Radeon X1950 Pro HDD|1x WD Raptor 74GB SATA 10000RPM; 2x WD Caviar SE16 250GB SATA2 16MB; 1x WD 500GB IDE; | OCZ GameXStream 850W Case| TT Armor VA8003BWS Black Vista Ultimate 64
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.0.6000.2.0.0.256.1
Files that help describe the problem
WD-20071111-1929.dmp
sysdata.xml
Version.txt
Extra information about the problem
BCCode: 117
BCP1: FFFFFA800802D4E0
BCP2: FFFFF9800421F558
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_0_6000
Service Pack: 0_0
Product: 256_1
We do not support multiple displays on two cards, both in XP and Vista The only mode we support with two cards is Crossfire (which means a single monitor is active)
If you just wish to run two displays, hook them both up to the primary card. If you are still having this Stop, or fatal error, remove the second video card.
One other thing that may reduce problems; and it's worth trying, is to reduce the amount of system memory, by removing memory panels. Consult your motherboard manual on acceptable configurations.
Another is:
In your BIOS are you set to dual PCI Exrpess card configuration?
My configuration:
