Hi,
I want to had a liguid cooling loop to my pc. For now it will only do the cpu. But I will add in a near future to the same loop for my video card (when I'm decide wich one I will get), this is the list of part I choose, if can give me your comments and/or problem you face with some part I really appreciate.
Pump: Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Rad: Swiftech MCR320 Quiet Power Triple 120MM Water Cooling Radiator Black G1/4 Threaded
CPU block: Swiftech APOGEE XT LGA1366 CPU Water Block G1/4 Chrome HI-FLOW 1/2IN Eurostyle Barb Fittings
Reservoir: Primochill Typhoon Split Window Single Bay Single Loop Delrin Reservoir with Front Window - Black
Fan : Silverstone Air Penetrator AP121 120MM 1500RPM 35CFM 22.4DBA Directed Airflow Cooling Fan - UV Blue X 3
Tubing : Primochill Primoflex Pro LRT Black 1/2IN ID 3/4IN OD Tubing (10 Feet)
Fitting : Bitspower BP-45R G1/4 to Rotary 45 Degree G1/4 Socket Fitting -SILVER SHINING- (Single) X 2 (1 rad + 1 res)
Bitspower BP-CPF-CC5 G1/4 to 1/2IN Straight Compression Fittings -SILVER SHINING- (Pair) X 3 (rad+ res +cpu)
There is 2 things I'm not totally sure about , Radiator and reservoir. The rest of the parts are most standard. If you can help me I appreciate.
Thanks
Thanks
