I've been looking at replacing my nearly decade old computer speakers (Altec Lansing 2100) for a while now. I've narrowed down my choice to a pair of bookshelf speakers, a receiver, and perhaps a sub. However, in doing research on this site I've just gotten confused with the various choices and information so I figured I would ask for advice.
First the receiver, the only major features I would like out of the receiver would be HDMI ports (for gaming systems) and the possibility of radio reception (HD radio if possible).
The Onkyo TX-SR508 was suggested to me by a friend. Is this receiver a good choice or are there any other choices?
Next the bookshelf speakers, I would be using this setup primarily for listening to music (mostly classical and post-rock with a little bit of everything else thrown in), and sometimes gaming or movies. However, I would like to pay less than $500 for the whole setup. Any suggestions on a good pair of bookshelf speakers?
As for the sub, I don't tend to listen to music with a lot of bass and I live in an apartment, so window shuddering sound is not possible. Would it be better to get a sub, or should I skip the sub altogether and purchase nicer speakers with that money? If I should get a sub are there any suggestions?
Finally some general information, I would be using a on-board sound card (Realtek ALC889) and using these in a small bedroom. Also, the less I spend on this project the better, so coming in under budget is a priority.
Also, is there a basic primer for audio information that I can read for future upgrades or anything like that?
