Help flashing bios.
maxse
Okay guys I am trying to flash the BIOS on my EPOX board but I cant seem to do it! Here is what I did:
I created a boot cd-rom from NERO and dragged the files that I needed...
Now everything boots fine and when I run the bat file that I need to updat the bios I get this message in dos:
"The system memory mamager EMM386.exe has detected an error caused by a fault in one of the device drivers or programs loaded in the system. Due to this fault the system is probably in an unstable state and you are recommnded to reboot immediately etc...."
Then it just says press ctrl al del to restart or any other key to abort...
What is going on here? Nothing is being loaded except the files on the boot cd that Nero created. So what is wrong. Can someone please help me out. Is nero a bad program to make boot cds?
Is there a windows based flash util you can use instead? Or can you grab an old floppy from somewhere?
yea it said I can use a floppy disc and press ALT F2, but I have no floppy drive installed in this coputer, or any of my computers for that matter.
Comon guys what is going on here. I need to flash this bios ASAP
