Help - Flashed with wrong BIOS on DFI LP NF4 SLI
Ok, I made a big mistake on a BIOS flash. I mistaked the model motherboard I am working on (DFI Lanparty NF4 SLI-DR) for a DFI Lanparty UT NF4 Ultra-DR. Yeah, it was dumb, and my fault. Totally embarassing :(.
After flashing, the system refused to POST. I reset the CMOS, and the system DID (thankfully) POST. I think this is a result of the CMOS reloaded.
I enabled NV Raid in the BIOS to boot to the OS, but afterwards, the system failed to POST. I reset the CMOS, and it POST'd fine.
Anyway, I set up a floppy with the correct (I am sure of this) BIOS and went to flash. It worked, but the same thing happened. When I change an option in the BIOS, the system fails to POST.
I hope I am not screwed over. I am hoping that I can simply set the main bios to the backup one (if that is the case), but I am not so sure how to do this. I also don't want to do something incorrectly and screw over any possibility of fixing things.
Thanks for any help.
Fortunately I was able to resolve the issue. It turns out I had the memory in slots 1 and 3 instead of 2 and 4. I didn't realize it mattered because this was not in the manual.
I reflashed to the latest BIOS and everything seems fine, except NVRaid doesn't work, nor do the SATA ports that work with NVRAID. The SATA ports with the Sil controller, however, do work fine.
Oh, just for reference, is it possible to transfer a raid array from one controller to another and keep the information intact?
Thanks.
