Help! First Build.
MikeFlide
This is my first build and i have the Thermaltake Tsunami and the DFI Lanparty nF4 Ultra-D
the DFI didn't come with any screws to attach it to the mobo. The screws that come with the Tsunami are wierd. Only 4 out of the 9 screw holes are filled. on the right side top and bottom. For the rest of the holes the screws are either too small or will bend my case.(I already bent the case a tiny tiny bit trying to get 1 screww in) I need to know which screw to use. And also can some post a pick of their DFI in place or atleast the type of screew that's supposed to be used to get it into place.
Mike-
You do know that you have to install standoffs in the case right. They should have come with the case. The standoffs go into the holes in the cae then your MB mounts on top of the standoffs and then you use the screws to hold the MB on the standoffs. Don't over tighten the screws, you'll crack the MB. Do NOT screw your MB directly into the case, it will short out. Checlk out this site for some photos a a MB install http://www.build-your-own-computer-tips.com/installing-a-motherboard.html
