lord infamous
- May 15, 2011
Hey guys.
I recently thought i solved all heat issues on my system when i learned of VRM bottleneck on my 5970 GPU's. I have a small room and it heats up quick with two VRMs hitting 90C in games.
I have decided to do my frist water cool on my PC and i understand the basics like res > rad > pump > cpu > gpu > gpu, but I am not comfortable finding the correct fittings and O rings, etc.
I have a small case ( antec 902 ) that I have modified by removing all HDD bays and mounting my HDD's on the botton of my case. I have a pretty high end system so I dont want a kit that will choke or be hot when install on my system..
I was wondering if something simple like this ( http://www.frozencpu.com/products/1...o_MCR320-Drive_Rev2.html?tl=g30c97s1076#blank ) would suffice for my system.. I doubt it, but I sure hope so..
Can you guys please see if the above would work for me and if not, please give me a list of ALL parts and fittings I would need to water cool my system. I am trying to spend about $ 300 bucks.
Specs:
EVGA x58 3x SLI
Antec 902
Corsair AX1200
i7 920 @ 4ghz on air
2x HD 5970 (2 dual GPU cards, 4 gpu's total)
6GB OCZ gold DDR3 Triple channel
1x 128GB SSD
1x 500GB HDD
Sound Blaster Xfi Xtreme Music
THANK YOU SO MUCH IN ADVANCE .. I really need help on this
Specs:
EVGA x58 3x SLI
Antec 902
Corsair AX1200
1x 128GB SSD
1x 500GB HDD
