Help finding pictures. Please.
Kaotix
I am working on a Quake III case mod and I am trying to find some good/high quality pictures of the weapons icons. Do any of you know where I could get some pics of the icons? Any help would be greatly appericated. Thanks.
Kaotix
Iv used Google and came up with some allright pictures but trying to find some higher quality pics as I will more than likely need to resize them. I attached the pics I found. These might work. Another question, Where can I get these pictures printed on photo quality paper as I dont have a printer? Thanx for all your help.
if you want, I can make you some vector files of those. if you have no way of resizing them, I can also set the size and put them in a PDF for you.
Kinko's should do it for you.
that's at the same size as above, but as a Hi-Res JPG. Let me know if you want a PDF and want it a certain size.
Thanx for all your help guys. It has been greatly appericated.
SpangeMonkee, you have a PM.
