help finding at replacement 24 pin psu cable
theman7233
as the title says it, ive been looking for over an hour with no luck.
ive seen a million 24 to 20 pin cables or 24 pin extension cables but no 24 pin male to male cable
help me out
This is for a modular PSU? Why don't you just contact the tech support of whatever brand the PSU is from and ask them if you can buy a new cable?
