Help Finding A Printer....
Izzeren
Hopefully this is the right forum for this thread to be in, if not I apologize. Anyhow on to what I am looking for.
I am looking for a good printer that will print directly to CD/DVD. I know HP makes one that cost around $100 but not sure how good it is really and I know Epson & Canon make them as well. I don't want a cheaply made printer, but I also can't afford to spend $1000 on one of those automated ones either atleast not right now.
I will be using this printer to do solely printing labels on the CD/DVD. My daughter goes to a camp every year for kids with or that has had cancer and I volunteer to copy their DVD movies that get taken at camp. Usually I have to do anywhere between 400 - 500 DVD's all in about a span of 1 1/2 months and printing them on labels and then peeling and sticking seem to take up alot of time so I figured I would see how this worked out.
So if anyone could help me out here I would appreciate it greatly since I have never bought one of these I really don't know how good of quality they print versus printing on stick and peel labels.
The quality is about the same as a halfway decent stick-on label. The HP that you're thinking of is a decent printer, as is the Epson around the same price range. I can't think of model numbers off the top of my head though. If you're printing in that kind of volume, I think it'd definitely be worth it to pick one of these up.
Ok thanks I appreciate it. I will probally go with the Epson that I saw since it uses 6 diff. cartridges and capable of high capacity cartridges. Hopefully I have good luck with the Epson since I have never owned anything but an HP.
Epsons go bad if not used in a while (heads get clogged). So, be sure to print at least one page with all colors once every two weeks or so, if by some chance you get a time period without needing to print a label.
Thanks for that heads up I did not know that. I will be using it to also help print out the DVD case inserts as well so that I can have 2 printers going at once doing that to help speed things up plus it will also be used some for my own personal use since I am paying for it out of my pocket and not the camps. It is a good thing I only have to do this once a year because I would go broke :p
