Help finding a motherboard
Compfreak999
I know you guys get a lot of questions regarding this and i appreciate any help you can provide. I've been out of the comp stuff for quite some time, no longer know which is a good motherboard to get. (I still miss the days when $130 gets you a top of the line A7N8X-E)
Anyways, i have a Intel Conroe E6700 chip, i want to pair it with a decent motherboard. (Brand whore here, Asus and Gigabyte are my prefered brands, MSI is ok too)
I know that some Asus boards have built in Wifi, that will be a nice + for me since this computer will be hooked up wirelessly. Overclocking isn't a concern, though stability and quietness are.
Oh yea, i probably won't need SLI, not really much of a gamer. Though i'm looking forward to getting a GPU that supports DX10 when Vista comes out.
ABIT AW9D MAX. Or, if you don't need extra leds and more than 4 Sata connections, the AW9D. You will never regret either.
there are a number of decen't mb's for the core 2's right now from inexpensive foxconns 965p and t-force 965pt biostars to outrageous overpriced asus nf-680i's .
the foxconn 965p's and biostar 965p's are on the bare side as far as options go --but some people like me like a more basic mb. the gigabyte s-3 and ds-3 are sort of no frills too.
gigabyte s-3 965p and ds-3 seem to be very good . as well as the asus p5b-2 rev 2 . p5w-975x and the asus p5b-delux 965p.
i also wouldn't write of a intel mb like the 975xbx or even a intel 965p since overclocking is not the main goal.
you should consider a bfg-680i or evga 680i if it come close enough to fitting your requirements .
considering you want wi-fi -- i would go with a wi-fi asus p5b- delux or p5w-975x as the top picks.
