Help finding a cheap mobo, SDRAM, AMD 1.2GHZ
Copyright
Im trying to fix a computer for my g/f.. ive got 256 megs of PC100, a 1.2ghz amd, 15gig HD, 52x cd burner, video card, sound card, floppy drive and case fan all left over parts. I need help finding a mobo that supports SDRAM and can run this 1.2ghz thunderbird. I figured a 133A would do the tirck but wasnt sure if there was anything faster that used SDRAM. Thanks for any input or links!
GL man...
I have almost the same kit at home 1.6 GHz Duron, 512 MB cas2 PC133, 2*45 Deathstars and graphic but the MoBo went down on me... I've had no luck so far...
Only thing ive been able to fine is some MSI boards that were orginally out of a gateway machine. Ive used one befor on a friends computer and it worked but would rather not have that gateway logo when it boots up.
You could probably find a used K7S5A that would "fit the bill"...
And before going and saying that they are junk etc...I'm running mine just fine as shown in my sig, and it comes from the same guys that OEM for Abit and several other big name brand companies..
MD
