Help finding a case
/usr/sbin
Successfully Trolled by Megalith
Looking for a few things, except most of the criteria I'm looking for isn't "searchable" on newegg.
► Good cooling, goes without saying. Would prefer a case with 4+ 120mm+ fan locations so I can use slow and quiet fans but still have adequate cooling.
►Dimensions Minimum 20" deep, 8.5" width. Prefer a sizable height as well, but the other two dimensions are more important.
►Removable/washable filters over all intake fans (HD/Side of case if applicable). Must have intake fans blowing on all HD cages spots because I fully intend to fill at least 6. Would prefer to have the filters "side loaded" so I don't have to pull them out from the bottom of case, which requires full detaching all cables, etc, every time I want to clean the filter.
►Good cable management. It doesn't have to be the best, but I'd like to keep it relatively clean inside.
►Not fancy. I prefer a plain old case. I don't like case windows. I don't like LEDs.
Having a hard time finding a case that meets my criteria..
