Ok, I'm totally new to crossfiring and as such don't really know what I'm doing. It would be helpful if I could find some sort of tutorial on this, but I can't find a decent one.
Here's my situation:
I've got two Sapphire HD4850 1GB ram cards. I've got them plugged into my motherboard (ASUS M3A79-T) that has a 790FX chipset.
My motherboard has 4 PCI-E slots, but says that for the ideal setup with two video cards I would put them in slot 1 and 3 (they support x16). However, I can't get the ribbon cables to connect the two cards together because they are about half an inch too short. If I put the card in the PCI-2 slot then they only run at x1.
Do i need to use the cables?
