HELP: Display port adaptors
SpeedyVV
I just bought a RX 480 which has the following ports:
  • 3 x DisplayPorts (1.3 and 1.4)
  • 1 x HDMI 2.0b
My monitors in a PLP configuration are as follows:
  • 2 x Dell 2007FP
    • DVI-D (Single Link)
    • D-sub
  • 1 x Dell 3007WFP-HC:
    • DVI-D (Dual Link)
Is there any combination of adaptors that will make this work?
You should only need 1 active adapter for the DL-DVI 30", the other ones will work with a passive dongle or conversion cable. Don't use the vga ports period.
Actually using all active cables is a good idea to avoid tearing on non-dp connections. You'll be good op.
