I'm using a dfi lanparty ut nf4 ultra-d mobo in this recently put together system. I've been having my hsf shut off persistently and I assumed it was one of those fan/power/noise conservation settings in the bios. So I plug my hsf power into the "fan 2" 3 pin slot on my motherboard and viola, constant running. In the bios i see there's a setting to shut the CPU fan off if the temp is >25 degrees, but I can't disable this or lower the threshold temperature. Any ideas on how to disable this? And i'm only getting 800ish rpms on my cpu fan from the second fan slot so running it long term though that is a no-go.
