Help dirt stuck between LCD and screen !!
Sc0ttFern
I have a 2005FPW and I was cleaning it today and when I was pushing on certain corners I *believe* that some dirt got trapped between the LCD and the outer screen.
Does anyone know an effective way to get that dirt out? Yes, I know for a fact that it is dirt because when I rubbed my knuckle on the screen it moved. Also when I used my can of air and sprayed it in the corners it moved around a little more.
Is there a safe way I can remove part of the front of the screen to blow some air in there to get it out. It is very annoying!!!
Thanks for any advice!
my 2005 panel (completely clean) moves when you press your fingers on the bottom corners , and why are you worrying about the dust if you can't see it?
what you can't see can't hurt you
I had a similar problem with my Syncmaster. It looked more like a strand of hair than dirt, but somehow I managed to spray the crevices in my monitor to the point where it was removed. Either that or I managed to spray it to the corner of the monitor. I would try that before disassembling your monitor.
I would also call the manufacturer for any help they maybe able to provide you.
