I have a Linksys WRT350N that I've been using for years but yesterday it just turned off. The power LED On the power brick was off so I swapped in a 12v/6A power supply and it would also turn off when connected to the router. I found that when plugging the original power supply back into the router, it would flicker on once a second but go back out. I've opened the router up but the power seems to get as far as I can follow and probe - I lose the traces after some point. I've removed the Wireless N PC card that is installed in these things but the power continues to die out and attempt to flicker back on every second. Before doing everything, I already tried doing a reset but the problem later appeared to be more severe with the powering on and off. The router has been tucked away its entire life without being moved. I can't find an internal short BUT I only get ~1k ohms resistance between positive and negative.
How can I find what may be shorting out the router? Any good way to find a short internally?
Edit:
I'm a retard - I didn't check one of the caps - the filtering cap. I'm getting 0.5 ohms on it so I'll solder a new one in tomorrow.
Edit:
