Help - Determining the source of a problem
Hexus0
Hey everyone, some of you might remember that I just built a computer for my friend's younger brother, here are the specs:
Lian-Li PC-61
Antec NeoHE 480W
EVGA 650i Ultra
C2D E6750 2.66Ghz
OCZ 2x1GB DDR2 800
HIS ATi X1950 Pro
Seagate 7200.10 SATA
Lite-on 20X DVD+-RW
Windows Vista
I built the computer about three weeks ago and its been working fine up until today. He said that while he was using it the computer just froze and wasn't able to use the mouse or keyboard, so he turned of the computer. Then he turned it back on and nothing appears on the monitor now.
At first I thought it might be just the video card, but now that I think of it, it could also be the motherboard (I think?). Is there any way to figure what the problem is exactly? I don't have another PCI-E card, so I can test that to see if its the video card. Any ideas?
Thanks!
Do you have another PSU you could test it with? Antec's quality on the NeoHE's is questionable sometimes, lol.
I have my NeoHE, I'll give it a try today or tomorrow, being sick + studying sucks :(
I tried my NeoHE 550 and still nothing. The computer turns on, fans spin, everything seems to boot up normally but nothing appears on the screen. Tried booting with just 1 stick of memory, still didn't help. Its down to the motherboard or the graphics card, what do you guys think?
Make sure a system speaker is plugged in or it has one onboard (the one that makes the POST beep). Pull out all RAM and listen for error beeps. If none, pull out the vidcard and listen for error beeps. If none, its probably your board or CPU, and CPUs rarely go bad.
