Help determine instability crash dump included`
XdVeLoPeX
On Wed 11/16/2011 6:54:59 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\111611-10904-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800998C028, 0xBE000000, 0x800400)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
I cant seem to figure out my bsod 124 error its not my vcore...
a quick search on WHEA_UNCORRECTABLE_ERROR
The WHEA_UNCORRECTABLE_ERROR bug check has a value of 0x00000124. This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
providing the dmp files could (possibly) help
may be worth trying to run a memtest and remove any overclocking
I'm guessing your OC isn't stable, but it may also be bad RAM. Follow what j-sta suggested: disable OC first, check stability, then try a memtest.
