I've been trying to wrap my head around designing a simple class A network that is easy to manage and allows extra room for growth. This is part of a case project for homework, and I've attempted to do some of the work but I am lost as to what I may be doing wrong.
Basically, I have 6 buildings in which I need to setup a Class A network for(1 router in each building). I have to use a 10.0.0.0 private IP address. There approx. 1,000 workstations between the 6 buildings, the max in one being 312.
I was trying to design a class A network thinking I only needed 6 subnets. Well, doing the math to find out how many bits I need to borrow, I find that 4-bits gives me enough subnets that I need. That's 2^4-2, giving me 14 usable subnets. Simple, right? Well, I waste a HUGE amount of host addresses that way.
The problem I was running into was I only wanted to configure about 2,000 hosts per site. Reason being a questioned was also asked what happens with my design should the hosts ever reach 1,024 'per' building. This should take care of that. Well, if I lower the hosts per subnet, I get a large amount of subnets, right?
On a 10.0.0.0 network with a 255.240.0.0 subnet mask, I end up with a little over 1 million hosts.
On a 10.0.0.0 network with a 255.255.248.0(trying to keep it at 2,048 hosts per subnet), I end up with a lot of subnets.
Is this something I have to deal with, with it being a class A network? I am trying to find more on designing class A networks, but there isn't much on it. There are several combinations using subnet masks I'm just not figuring out how to do the simple one I want.
Also, is CLSM or VLSM better for this configuration? All the examples I have for CLSM are for Class B and C networks.
Thanks in advance!!!
Please feel free to ask for anymore details.
