Chevyman03
- Apr 4, 2005
I'm looking into watercooling my system and am looking for advice. My current system is a Coolermaster stacker filled with fans, Gigabyte 965p-ds3, E6600@3.51ghz, Blue orb 2, OCZ 600 Powerstream dual rail, 6800gt, and Corsair6400 2x1gig. My voltage is @1.35 vcore and temps currently running 44c idle and 68c max full load under orthos. My ambient temp is around 70f now since its winter but will get very hot in summer mid 80's thats why I would like to do watercooling. have a decent budget give or take $200?. I figure I should have decent room in my stacker case as its pretty large? I would like to have the ability to add watercooling to a gpu also. Ideally a system I could use for many years and adapt to new cpu's and possibly gpu's? Thanks
