daemionsos
- Dec 20, 2005
My 19" widescreen is great for gaming. But I like my 19" 4:3 better for desktop applications.
idoc said:I recently upgraded from a 17in CRT (at 1024x768 res) to a 17in LCD. The increase in screen area is very evident, but text size is quite small for me at the LCD's native resolution of 1280x1024. I need to wear my reading glasses for more comfortable viewing, unless I increase DPI setting to 120 (from default 96).
I'm now considering getting a bigger LCD instead, and was considering the 19in or 20in WS but after reading this thread, it seems that I wouldn't be getting any improvement in text size since the actual vertical screen dimension would actually be less than or just the same as my current 17in LCD. I know that there will be more pixels, but text would still look small at native resolutions of 1440x900 or 1680x1050, right? Am I correct in thinking I'm better off getting a regular 19in LCD instead? 20in (4:3) LCD is not available here.
Snowdog said:The important number is pixel pitch. Yes you can change the DPI setting but that doesn't work smoothly on everything. I think you might want to look at screens with pitch in the .290mm range. 19" 5:4 or 20" 4:3 1400x1050. Next would be the 19" 16:10 with .285mm.
LCD pixel Pitch at common sizes/aspects/resolutions:
17" 5:4 .264mm (1280x1024)
19" 5:4 .294mm (1280x1024)
19" 16:10 .285mm (1440x900)
20" 4:3 .255mm (1600x1200)
20" 4:3 .292mm (1400x1050)
20" 16:10 .258mm (1680x1050)
21" 4:3 .270mm (1600x1200)
21" 16:10 .270mm (1680x1050)
22" 16:10 .282mm (1680x1050)
23" 16:10 .258mm (1920x1200)
24" 16:10 .270mm (1920x1200)
30" 16:10 .250mm (2560x1600)
