help dell 30 broke
p3sty
ok have a 30 inch dell 3007fwpt broken screen where is the best place to buy replacement panel?
Better to just buy a new screen. The panels on those go for $300-$400 on ebay when you can find them. I believe they are the same panel as the old Apple 30" Cinema Display so you can look them up that way as well if you do decide to buy a new panel. Unless someone else knows of a better place to buy them.
I'd look out for a cheap broken 3007wfp with characteristics that indicate a board failure.. like power inverter/electronics etc.. MisterDNA did a similar fix for a 3008wfp in this thread.
