Help deciding between 2 mice
They're the same mouse. If you compare the boxes, you will see that the features are the same on the bottom in the squares. The only difference is the color and whether you want a 2-tone mouse ;)
Good choice of mouse,
...Dan
I would suggest you consider going with the G5 instead. The batteries used in the G7 suck and the texture on the original G7 is slick and builds up gunk on it very quickly.
My G7 works perfectly. I only need to exchange batteries once every 2 weeks. That is with about 2-3hours usage each day. Sometimes more. That carbon fiber one looks pretty cool....
