(computer in sig, it works fine normally)
Hey, my CPU won't OC in windows. I set the CPU freq up in BIOS, HT multi @ 4x, RAM divider at 166 (RAM @ 3-3-3 1T manually), and reboot. BIOS says the correct speed, but in windows nothing ever changes! CPU-Z, the my computer properties tab, dxdiag, they all say 1.8Ghz no matter what (I've tried many different CPU freqs, such as 210, 225, 230, 240, and 250).
I can change the voltage however. I tried a .025V increase, and instead of saying 1.379V, CPU-Z read 1.4V, so that works. A RAM divider works, because when I put it on, my 3dMark05 score goes from 7550 to 7400. But no matter what CPU freq. it's at, the 3dmark score doesnt change! I got 7401 @ 230 and 7403 @ 250. -_-
HELP!
edit: it's not a temp problem, i checked my temp while 3dmark was going and after several minutes of 100% cpu load it went from 26C to 38C.
and "AMD Cool 'n Quiet" is disabled.
HELP!
