Here is the story. The other night, I shut down my computer, and by mistake, I hit the power button, causing it to reboot. When I realized what happened, I held the power button in to shut it down. The next day, when I went to boot it up, I got a message saying something like missing/corrupted system32.dll... Insert Windows Setup disk and press r at the first prompt to attempt to repair the problem. I do have 2 different hd in the computer. The c: is my primary and had my legal xp pro installed with sp1and has been working for nearly a year now. My second hdd was from an old setup I had where the o/s was installed, but did not have all the drivers, cards, etc installed. It is not the same o/s as my legal setup that is on c:. I can boot into the second drive by changing the setup in the bios. I cannot install all the updates or sp1/2 on the second drive. I did get the internet connection working, but that is about all. When I click on my computer, then click on the cd drive, it appears there is no disk in it. I even tried putting a different disk in it, but it will not read it either. The lights on the cd rom will flash on and off when disk is first inserted, but it won't read the disk.
Here are my problems:
1. Box would get to the screen above but would not go any further. I had to hard power it off or reset it to do anything.
2. When I try putting the Windows XP Pro update disk in to boot from it, the CD drive is not showing a disk or any files on the disk at all.
3. Now, when I change back to the c: drive in the bios and try to reboot, I no longer get the message about a corrupted file or anything. All it does is shut down automatically and attempt to reboot, and the whole process starts all over again.
4. The c: drive is ntfs and the second drive is formatted in fat32.
5. I have connected the 2nd drive to the net and installed all the updates to it that I can, but primary will still not boot and cd rom will not read from o/s in 2nd drive. I hoped the cd would start working after the updates were completed, but it will not.
6. I have tried to run restore on the c: drive from the 2nd one, but it is only showing restore points since the problem and nothing prior to it happening.
7. Since the cd rom will not read, I can't run the update/setup disk to repair the problem.
As I said before, I have to go into bios and change the setup to boot from the 2nd drive to get it to boot, but I still can't get into the c: drive.
Any suggestions on what I can do to get it up and working again? Thanks in advance.
Almost forgot...since I can't boot with my c: drive, I cannot boot to safe mode.
