Monkeypillow
- Aug 30, 2006
I recently purchased two GTX 260s that I intend to water cool, but first, I need to know what components need to be cooled.
So fa, I have the GPU itself (water block) and the RAM (Enzotech BMR-C1 ramsinks) taken care of, but I'm sure there is more.
How can I tell what components need to be cooled? Should I just remove the stock heatsink and count the contact points? It'd be easier if someone had already done that and could just tell me.
For the smaller components that end up needing to be cooled, I'll probably end up using aluminum heatsinks, as they won't get nearly as hot as the RAM.
Any help is greatly appreciated.
