deadman_uk
- Jun 30, 2003
I own the D-Link DIR-615 Router which I use with my Virgin Media NTL cable modem (Ethernet). My dad wanted to go wireless so I recommended him the same Router I use which he has now purchased to go with his Virgin Media DSL 4MB connection (Thomson Speedtouch 330 modem) but there is a problem. The Router only has a connection for an Ethernet port but the modem is USB based with no connection for an Ethernet cable. What can be done here? Is it possible to use another modem? one with an Ethernet connection? or perhaps an adapter/converter can be purchased to turn USB into an Ethernet connection?
Thanks for any help
Thanks for any help
