ProfessorKaos64
- Sep 18, 2009
Im having issues with my macbook recognizing my server 2008 pc automatically , it has the file sharing role on, network discovery is on with the services needed, but it wont show up on my mac, any ideas? its part of WORKGROUP, and named.
simple issue thats driving me nuts since I switched from Win Server 2003 to 2008. I even went as far as shutting off SMB 2.0 for compatibility.
I can manually add the SMB share by IP address using COMMAND+K, but it won't automatically pick it up.
Any ideas?
Thank you,
Any ideas?
Thank you,
