I've got the actual htpc built, but I'm at a loss on how to go about connecting it to the entertainment system so that I have video/audio output and also video/audio input for PVR functions.
Right now the enetertainment system is setup with a 36" Proscan Standard Def. TV, an Onkyo TX-DS676 Receiver, Generic progressive scan Panasonic DVD player, proscan VCR, and an older DirecTV sattelite box with a serial port on the back.
The audio on sat. box is connected via analog to video 1 on the receiver, with an s-video going to the TV. The DVD is the same only for video 4/DVD. The VCR is also the same (but for Video 2) only instead of S-Video, it's a component video cable. This leaves me with Video 3 which only has input connections.
I don't care about removing the VCR out of the picture since it's never used anyway. However, I don't have any S-video ports left on the back of the TV. The receiver has an S-Video port for each channel, but no channel has a video cable plugged in, it all goes directly to the TV.
The HTPC setup has a Geforce FX5200 card with S-Video output, and a Hauppage PVR150 for recording. I was planning on using the onboard sound on my Asus A7N8X Dlx. Rev. 2 for everything, using a digital coax audio cable for the output.
I really don't deal too much with entertainment systems, I'm more computer oriented, so I guess I'm just a little overwhelmed. I have no idea how to plug in the HTPC to get the best Input/Output on it, while still being able to watch DirecTV through it. Any tips on if/how I should rewire everything so it all works flawlessly together?
