Help, Computer won't boot
Diraan
I just recently upgraded my system to:
E6400 Core Duo
8800GTS 640mb
2 Gigs of Ram
P5B Mobo
Dual layer burner
550W Power Supply
150GB Raptor
120GB SATA WD
I just finished building it and it won't boot into Windows. I have Vista 32bit running on the raptor from a previous system.
Power on goes something like this:
Power On,
Post BIOS screen
"Selects Start Windows Normally"
Vista Loading bar gets about 80% done then flashes to a blue screen for about a second before it powers off.
I'm not sure what to do at this point. I'd like to say that I have some experience building computers but its been about 5 years since I've done a complete overhaul and I've never encountered this error before.
You need to re-install Windows...... Your old hardware has its signature in your Windows install and won't work properly with the new hardware.
You *MIGHT* be able to get away with a repair/upgrade install so that you don't lose everything but it might hose some of your programs.
i just came to the same conclusion. But when I said to reinstall vista it says that my Key is Invalid.
If I have an upgrade version of vista do i need to reinstall xp again from scratch?
AFAIK you shouldn't have to have XP installed to install the upgrade version of Vista, you should just need the XP KEY. Maybe I am wrong there but that is how the older "upgrade" versions went.
EDIT:
Guess I was wrong. But try THIS.
jbmx4life, I am doing that right now. So far so good.
I'll post here again in an hour or so when the install finishes
okie dokie.... Imma wait for your response to see if that really works or not :p
This is why I never buy "upgrade" software. Looking at your specs, I'd figure the system you're upgrading from is significantly different, expecting windows to boot is naive. Especially Vista, the DRM in that probably laughed at you, cross-referenced your IP with your phone and mailing address, then contacted M$ to have them take your first born for pirating their software onto another computer! bA5turdz!! :eek:
Hope your repair works, but with brand new hardware such as this, and an OS fresh out of the gate, I wouldn't be optimistic. I'd expect to reinstall from scratch. Even if the repair works, there could be lingering issues that nobody yet knows how to fix. Bear in mind that both Nvidia and ATI have yet to release a stable driver, at for the 64bit Vista. But if you don't go 64bit, you lose most of Vista enhanced security features.
You buy the latest and greatest, you get the most expensive, pre-release, incompatible, unsupported crap. Wait six months, Vista should be fine then. But just in case, wait until the "experts" say it's ready. Right now, it ain't.
I reload systems nearly every day. You don't know until you try it sometimes, and the least destructive method should be tried first. Just my .02
Well, all is well. The 'trick' worked.
I am installing new drivers right now. But I can safely say that the new DX10 demo (cascades or something) runs beautifully.
