Recently my fan on my video card went out, I RMA'd it and while I wait for my new video card, I bought a 9600se so i cloud get it up.
about two months ago my pc started acting wired!
when I would reboot, it would start to load windows and reboot, then after a couple of times boot fine.
Thougth that I needed a windows rebuild and ignored it.
About a week ago I noticed my computer cpu fan was running on lower rpm's. So It was a sat , i went and bought a used retail cpu for my p4 (all that I could find in twon) and ordered a super sielent 4pro l.
When I replaced the old cpu fan with the used it, it noticed some dark coloring on the cpu, and it looked worse when I put on my new fan. When I first built my computer I put some grease on but I didn't have any when I put the used coolier on, and I ordered some when I ordered my new coolier.
So I put on my new coolier, put in my new temp video card and everything looks fine.
the coolier loooks good, seems to be working fine, cpu runs at low 30c's
Boot the system, reboots, reboots trying to get into safe mode, try agian, boots into windows, reboots within 3 min, contuies to do this while I reinstall drivers and so on. sometimes saying IRQ not equall or just reboots or win32.sys error.
No luck, I think that my windows must be bad, so I reinstall.
Format go's fine, copies files, asks to reboot.
Setup starts fine, but reboots, restarts setup gets to installing devices reboots, does this randomly.
So Now I think that a hardware device is bad.
I try another power supply, still does it, try another video card, still does it, tried one stick of ram, tried switching sticks of ram, even diff slots, still does it. tired diff hard drive, still does it.
I am running out of ideas.
Is there a way to test cpu/ motherboard from dos or bootable cd?
Does anyone have any idea's?
I need help, any would be great.
Thanks
Thanks
