Help Comp won't power up
csidd
Not sure if this is the right forum but here goes. I just finished putting together a computer with some spare parts I had lying around. I tried to boot but when I turn on the power it starts up for about 5 seconds then it shuts off. WTF. Here is the setup.
Abit KG7 Raid
AMD XP1800+
1GB pc2100
40BGB Seagate
ATI 8500 64mb
Power supply came with the case 350w
Ihave 3 fans plugged into yhe power supply along with cd rom/floppy/HD. Any help will be greatly appreciated. Thanks. Is the power supply not big enough?
The hsf is a four pin connected to the PS. It's a 92mm Delta 38mm thick. In my other case I had no problems using the four pin. I'm guessing 350w PS should be fine. I tried disconnecting fans but that did not help.
