DubiousDoc
- Jul 29, 2004
Hello all,
System was cooking along for a few days and I had to continue to monkey with it.....
Anywho, was running Sandra to Benchmark it and the system gave me a Blue Screen.
I try to reboot it gives me NTLDR is missing error
I tried this
>Insert and boot from your WindowsXP CD.
>At the first R=Repair option, press the R key
>Press the number that corresponds to the correct location for the installation of
>Windows you want to repair.
>Typically this will be #1
>Enter in the administrator password when requested
>Enter in the following commands (X: is replaced by the actual drive letter that is
>assigned to the CD ROM drive.
>COPY X:\i386\NTLDR C\:
>COPY X:\i386\NTDETECT.COM C:\
>Take out the CD ROM and type exit
and all I get is access denied, I can access the bios, I just can't get windows to launch.
I also was running into Verfiying DMI Pool Data running and running and running......
Should I just reformat
Hardware:
MSI K8N Neo2 Plat
AMD 3500+ Winchester
1 gig Corsair TwinX3200
WD Raptor 74 gig sata
ATI Raedon9800XT
Audigy2z
I tried this
Hardware:
MSI K8N Neo2 Plat
ATI Raedon9800XT
Audigy2z
