Help chose ram for i7 build
that board supports more than 1333mhz, and in order to get to 4ghz on an i7 you're going to need at least 1600mhz ram.
Also any set of ram should be fine, just get a reputable brand like corsair, g skill, etc.
also ram with low voltages are usually a plus when it comes to OCing the ram.
how do you know if u get a d0 stepping. i want to build an i7 but i dont know how to look for that.
Model #: BX80601920
Item #: N82E16819115202
Model #: BX80601920
to answer your question, S-Spec has to be SLBEJ for it to be D0, C0 is SLBCH.
