guitarguy6
- Oct 29, 2007
Hey guys, several years ago I built a custom watercooling loop for my cpu. I had never WC before so I did a bunch of research and with some [H]elp I went with a Thermochill PA120.3, EK Supreme full copper cpu block, Swiftech MCP350, Primochill tubing and feser one coolant. I don't know how it happened but my radiator started leaking. I took it out and replaced it with an air cooler but would like to get my loop up again. I don't think I need quite as big a rad as I don't plan an WC my video card so I'm thinking just a dual 120mm rad. Any recommendations? I vaguely recall there are different barb sizes so I need to make sure it will work with my cpu block and pump. How much coolant will I need? I can't remember if I used 1 or 2 bottles last time. Anything else I'm forgetting that I'll need?
Thanks!
Thanks!
