TheHobbyist
Hugs Hard Johnnies [H]ard
- Apr 8, 2008
Hey guys. My current system has 4 sticks of the "magic" samsung low voltage ddr3 ram that truly is "magic." However, it appears it has become pretty rare. I am now on a quest for an 8GB DDR3 stick that is less than 39mm tall and can operate at 1866mhz Cas 8-9 (preferably with low voltatge).
Looking into the ram scene again, it would seem that there are about 4-5 ram chips (IC's) that are found in all of the different DDR3 that is out there on the market. If a stick is using the same IC, it will have the same performance more or less, regardless of what it is priced at or "spec'ed" at. This is important to know, as many times a basic, inexpensive "8GB DDR3 1600Mhz Cas 9" stick of ram can have identical performance to an expensive "8GB DDR3 2400Mhz Cas 9" stick of ram when manually tuned in the bios as they use identical IC's.
I haven't looked into ram in a long while and I was wondering if anyone was familiar with what is out there and can help me find what I'm looking for.
Some basic investigation has revealed that at the 4Gbit density, the two IC's most commonly used are from Hynix and Samsung. Any information that you guys can share would be greatly appreciated.
