Been out the loop as far as PC hardware is concerned..Just looking for the cheapest, fastest, most reliable drive with at least 250-1T Gig. Usually WD are known. http://www.newegg.com/Product/Product.aspx?Item=N82E16822236345 This is the hdd I was looking into. What do you think?
As far as RAM I am running G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL. I really want to bump up the RAM to whatever is best for gaming & multitasking. However, is it not possible for me to get a 4X2 set of the same ram and run it with the (2X2) set? Not sure what to do about the RAM, any ideas? I am on overclocked intel core i5 750 2.66@3.8 with a gigabyte GA-P55A-UD3 mobo
