Help Choosing a new S-IPS and more
pc1x1
Basically I use two Sceptre NagaV 19 widescreen monitors. And quite honestly they are great. Though I am doing more work on photoshop and whatnot (I game occasionally so its not a must, but low response times are preffered), and thinking of upgrading in a bit.
My dream set up would be this at 1080P
[ 1 ] [ 2 ] [ 3 ]
[ 4 ] [ 5 ] [ 6 ]
However there are budget constraints. I am thinking of having Display 5 being S-IPS and the rest just plain good monitors. If they are as good as my current NagaV, then I am satisfied, though I'd want display 5 to be S-IPS, as thats the main one I will be using photoshop.
Originally the plan was get another NagaV, I have 3, and use those as 1, 4, 3, 6. Then buy two new sceptres for 2, 5.
Unfortunately No place seems to be selling the NagaV anymore, and also, Sceptre doesn't seem to make any S-IPS models.
Is S-IPS overated, or something I should honestly consider?
and also I'd prefer to that all monitors are the same brand, originally it was going to be the sides are all 19's and the middle one's 24's, for the 1080p goodness. I realize thats a bit wacky, but 6 24's are impossible.
Any suggestions, how I should tackle this problem?
I was thinking maybe buying Samsungs, and doing 19's on the side, then 24's in the middle, but don't know if I like that idea, as different resolutions and the aesthetics wouldn't be harmonious, overall it would have been better to go all 20's and or all 22's but their resolutions aren't there yet, My stand only support up to 24's.
I am open to anything, even maybe just buying 3 monitors now, and then as I save up add another puppy to to the stands etc.
I am open to anything :)
Why 6? Because of the resolution? How about 4 identical ones? Or 3 -- a 24" in the center and two smaller ones on both sides in portrait mode?
The 6 originally was due to the resolution limits of the 19's.
However right now I am thinking of going into 3 panel set up. At least for the time being.
4 Identical ones was the original plan, then prices came down, and I went crazy :p.
S-IPS is not overrated, its not perfection as some forum members here herald and certainly has a few particularities.. but still its tops for color critical work. However if you are planning on sitting over 2 feet from the main display, a good P-MVA or S-PVA is hardly the sacrifice some would make it out to be.
Getting all the right monitors under the same brand seems like a bit too much to ask for though. You'd kinda have to pick and choose the best value/performance from different brands, unless you do not mind spending top dollar for all professional grade NEC or such.
I personally would get the center model as a 24" VA to keep bugets from flying, and the side 20" as IPS for sure as they will be off angle and closer. All that matters is that the vertical resolution is harmonious, so aim for 1600x1200 on the 20" and 1920x1200 on the center(which all 24" are anyways)
Any suggestions on particular models, and whatnot?
I sit on average 18 inches from the screen. Honestly, my NagaV's which I presume are TN panels, are absolutely gorgeous, I am still learning, and perhaps my eye isn't trained yet, but I am not over zealously picky. But I figured been working so hard, and will eventually be able to upgrade, might as well step up. Heh.
if you are going for something that big why not just go for a TV, or make a DIY projector?
I like big but I'd prefer not to go over 24, I think 30 is a little to big to be practical, and can't imagine starring at it for long times to be good, hehe.
