help choosing a cheap but good lcd
SpitFire000
OK so heres the deal, for the past three or so days i have been non-stop researchgin LCD's in the 20"+ widescreen range.
What I do:
Game: i play DoD DoD:s Cs Cs:s HL BF2 and GW ALOT
Graphics: I do a decent amout of graphic design for local organizations and what not, using photoshop.
What im lokoing at:
LG 20.1" L204WT
Viewsonic 20.1" VX2025WM
Viewsonic 22" VX2235WM
Acer 20.1" AL2051W
im leaning toward the 2025 but i dont think ill like the AG coating on it, it also has som problems with BB . The LG isnt a truw 8-bit panel meaning no good for graphics, right? then there is the acer and 2235 , the acer i think i will like but the aesthetics are horrid, and i have read alot about the 2235 but cant seem to find the cons of it(not true 8bit?)
well point me in the right direction, always recomend somehting if u feel need it be, but im trying to stay below the $400 area shipped/ with tax
BTW im using a evga 7900gt soon to be water cooled and oced
If you've been doing research then you should know that 2 of those are TN panels (LG, 22" viewsonic) and the others (Acer Al2051W, Viewsonic VX2025W) are P-MVA and the strengths and drawbacks of each technology. You should base your decision on what's important to you...each of those panels has fans that sing their praises and haters also.
Dell 2007WFP 20.1" Display............great panel for all your needs also on sale right now for 373$ with free shipping.....ive seen it a few bucks lower around 240 before.....give it a look and check out the reviews...great warranty and return policy within 3 years Anything at all happens to it you get a new one sent without being without a moniter.....and not to mention it ahs 2 usb ports in back 2 on the side and it ahs a composite video input and also an S-Video input for tv viewing or dvd watching on the displaynot to mention has picture in picture and picture by picture wich is pretty sweet you can view tv or movies in the pip and do other work at the same time check out the details and description ive attached here for you to read and see what you think check out the url for pictures!!!.....well worth the money and a great display!
URL - http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-4688
Details:
The Dell™ UltraSharp™ 2007WFP 20.1-inch Widescreen Flat Panel LCD Monitor is a wide aspect desktop display that redefines the performance of LCD displays with a stylish Dell™ industrial design, and advanced functionality. With this monitor, you can watch DVDs in natural format, run multiple applications simultaneously and improve productivity with less scrolling and toggling. The 2007WFP provides an excellent option for video editing and 3D imaging as both source and destination video can be viewed in a single window. It also supports advanced features such as PIP (picture in picture) and PBP (picture by picture) and can be activated with a touch of a button right in the front of the display. With the included height adjustment stand, every user can adjust the display to their exact comfort level and help reduce eye and neck strain. Dell-branded monitors undergo exhaustive testing for performance, reliability, durability and compatibility with Dell™ systems.
Highlights
* Display sharp and brilliant images with 1680x1050 Pixels resolution
* Wide viewing angle of 178º — horizontal and vertical
* 800:1 contrast ratio and 16 millisecond typical response time for distortion-free, sharp images
* 4 USB 2.0 high speed ports for connecting peripheral devices
* Ideal for multi-tasker, high end graphic designer, content creation user, financial sector and gamers
* Supported by Dell™ Technical Support
Do you have a Colorvision Spyder2Pro or similar? If not, no amount of money you put into a monitor will help.
your welcome....trust me you wont be dissapointed at all with that Dell Ultrasharp they are great! let me know if you have any questions!
SpitFire000 said:
no i dont im looking at the 2007 and its very apealing. Thanks for the suggestion
Then what good is your graphics design if all your colors are off? :confused:
yeah the dell wouldnt be for gaming at all, too slow!!! go to CC and look at the LG, it IS an 8bit, i called them and asked, and it says on thier site on the PDF for that monitor. where did you see it was 6 bit? heres thier sites link..... l204 specs
