The 1200 is not exactly quiet. The PC-X500 isn't really set up for watercooling,
Don't know much about the P193, but I had a P180B and it wasn't exactly watercooling friendly.
Not all that familiar with the TJ10, aside from knowing it's huge.
I'd look at the Cooler Master HAF-932 and ATCS RC-840 as well.
Otherwise good but HDDs won't stay quiet in that: screws connecting drive directly to metal cage and then there's open hole in both ends of cage for maximizing noise leak.SilverStone TJ10
I just bought A Lian Li PC-A77B. It is huge I bought the top for it with 3x120mm fan holes set up for a radiator from the lian li factory! The front of this case is straight drive bays so you can put a 4x120 rad there if need be.
I just got that case and an i7 920 with the Asus p6t6 WS REVOLUTION. I used a promo code that is good untill APR 02 and its on the small business section 25% off all accessories that means cases, processors, memory, graphics cards, motherboards etc. I saved 320$ on just those 3 items.
http://www.youtube.com/watch?v=ccIH8rlsKLU This is where I first saw the case I always wanted but never know it existed.
antec 1200 seems corny with the fan ontop if it wasnt for that I probably would have already bought that case and never saw the PC a77
The 840 looks impressive, but is it quiet or does it sound like a wind tunnel? Apparently the aluminum that it is constructed from is pretty thin.
Any case can be used for water cooling, you just have to be willing to do a little DIY and get your hands dirty
I'm assuming since you're doing w/cing you wouldn't mind cutting some holes, mounting radiators, and optimizing your loop right?![]()
