Help choose lcd tv
liquidgeforce
hey im planning on buying an lcd tv (after i sell mmy 2 existing 23" displays here on hardocp, check out my thread) but neways i need a little help. my main reason for going lcd tv is that i will be using it once xbox360 comes out, so i need a killer display for that, and i need one for my comp too, and i can hook both up at the same time. my only thing is i realize that the refresh rates will be something to worry about as well as ghosting, thats why i need your help, these are some i picked out.
http://www.newegg.com/Product/Product.asp?Item=N82E16824160139
Thats the AOC one. never heard of the brand but for that price the refresh rates, resolution, response time and size look good
http://www.newegg.com/Product/Product.asp?Item=N82E16824231001
this one looks good too, but no dvi input and a name i never heard of
Then theres this one
http://www.newegg.com/Product/Product.asp?Item=N82E16824179017
this hyundai is huge and it looks awsome, the price is right too. the only thing is i read some reviews that its not too good for gamig, wich is a big thing for me.
so if u guys can help or recomend some others, my max budget is a grand, but id like to spend less if i could thnx
