HELP can't print over wireless to a networked printer
nismohks
i have a Brother HL5250DN printer which is connected using an ethernet cable to my wireless router and i use a laptop with wifi to access the net and other computers using this router.
it is a belkin 54g wireless router.
anyway if i connect my laptop using another ethernet cable to the router, i can print, however once that cable is disconnected and i log on to my wireless channel i can't print.
i have installed the network driver for the printer( proof it works since i can print using a lan cable to the router).
any idea?
funny thing is that we also have a MAC OSX powerbook and that can print over wireless no problems at all using the standard driver package for mac osx from brother/
any ideas??
Hard to say, but one thing I would recommend is manually assigning an IP address to the printer. Give it something like 192.168.1.255, basically something out of the range of address that the router automatically assigns your computers. If you don't do this then the printers IP address can change from time to time and the computers might not be able to find it. If you already know this, sorry for being redundant.
I assume they are assigned the same workgroup since you can print when you're hardwired. Can you see the printer as a device while you're on wireless and you just can't print to it, or is it completely invisible to your laptop?
no i disabled the firewall
i cant see the printer if i browse the network or workgroup (the router does no thave a workgroup or anything its just connected straight to the lan port of the router)
the router has an IP already which was given to it automatically from the drivers which is out of the addressible range to the computers.
no idea. esp when the powerbook was fine from day 1!!
thanks for your help so far
It's a TCP/IP issue. When you add the printer, create a port, create an IP port and add in the IP that the printer is picking up. (Be nice if you could make it a static IP). Get your IP stuff straight and that port and you should be good.
how do i find out the ip and the port? i can't seem to see it connected on the router config page.
The printer should be able to print out a test / config page. You may have to go to the support page for the printer like www.hp.com and see if you can find the key combination to print this for you. Once you find out the IP address it's picking up then just create a printer in Windows with that information.
hmm i couldn't find the test print button or combo in the manual (or maybe i'm just blind) but i fixed it! well... i think so far lol
anyway what i did was that i reinstalled everything and found that there was this settings thing on installation where i can specify an IP, gateway and subnet.
so i gave it an IP of something within the routers range (ie 192.168.2.10) and a subnet of 255.255.255.0 ( i dunno why but it was an example in the manual) and i left the gateway 0.0.0.0 (once again i have no idea why)
then i configed the printer in the windows scanner and printer options panel and put checked the same option under the Ports tab and it worked!!
funny thing though.... i changed all this stuff on my winXP laptop... but i then used my powerbook mac and tried to print a test page thinking it would fail for sure since i changed the ip and all that...
guess what??
MAC OSX DETECTED THE CHANGE SOMEHOW AND IT WORKED PERFECTLY....
is Mac OSX really that good??
thanks for all your help guys anyway!
