HELP! Can't get my computer to boot up anymore
LeGenDz
I'm not sure about the process of going through this but this is what I did.
I got a new computer so I tried throwing in the HD from my old ocmp into my new comp. rebooted ran through Seagate wizard (its a Seagate) but it does not recognize the HD at all. Went into BIOS to see if I could do anythign but it does give me any other options besides "OFF". So after messing with it for a a while and trying to get it working I giave up and deicided to throw it back into the old comp and just use it. BUT when I put it back in the old comp now THAT gave me the same error! Someone help! :(
I got the old system to run again, but when I retried the new system with my old HD it DID recognize it but it would show boot up option screen where I can load Safe Mode or Continue Normally in which either choice just send it back into a loop of restarting and going through the whole process all over again.
are the jumpers on the hard drive out of place? does the other hard drive not have windows on it so it doesnt really do anything?
Are you trying to boot the computer using the OS that was installed on the drive while it was in the other computer? If that's the case, chances are very good that is never going to work.
Also, what exactly did the Seagate wizzard do?
No, the jumpers are set correctly. Its the exact same comfiguration as my old computer. My old drive does have Windows on it from the previous computer.
